This section will help you getting started with LDraw on Linux. You need system operator rights (the password for the "root" account) to follow these instructions.
Before You Start...
These instructions assume you have some tools installed on your
system. Here is a list:
wget
You can check if you have
wget installed with the
command:
wget --version
If you don't have it, you may download it from http://wget.sunsite.dk/.
- Perl
You can check if you have Perl installed with the command:
perl --version
If you don't have it, you may download it from http://www.perl.org/.
bzip2
bzip2 installed with the
command:
bzip2 --version
If you don't have it, you may download it from http://sources.redhat.com/bzip2/.
- GNU Compiler Collection
- LDraw tools for Linux come in source code form, so you need the GNU
Compiler collection (at least
gcc and make)
to translate the programs to executable form. These tools usually come
in the "development" section of your Linux distribution.
Step 1 (latest update 2006-01-06):
Download and install the LDraw Parts Library.
user$ cd /tmp
user$ wget http://www.ldraw.org/files/unix-complete.tgz
user$ su -
Password:
root# cd /usr/local/share/
root# tar xzf /tmp/unix-complete.tgz && echo OK
OK
root# mkdir -p ldraw/bitmap
root# chmod a+w ldraw/bitmap
root# chown -R root.root ldraw
root# exit
exit
user$
Step 2 (latest update 2006-01-06):
To view ldraw model use LDView.
You can install RPM or tar.gz version (available on
sf.net),
or build from source.
To install LDView3.tgz (root permission is not required):
user$ tar zxvf LDView3.tgz
user$ cd LDView3
user$ ./LDView
To install from RPM (root privilege is required):
root# rpm -i ldview-3.0-1.i386.rpm
To build from source:
user$ su -
root# cvs -z3 -d:pserver:anonymous@cvs.sourceforge.net/cvsroot/ldview co LDView
root# cd LDView/QT
root# ./makeall
root# make install
root# exit
user$ LDView
Step 3 (latest update 2002-05-23):
Install LDGLite. LDGLite is a rather
efficient tool for showing building instructions "on the fly", when you
download them as ".dat", ".ldr" or
".mpd" files from the web.
user$ cd /tmp
user$ wget http://ldglite.sourceforge.net/ldglitesrc0_9_5.zip
user$ unzip -uoa ldglitesrc0_9_5.zip
user$ cd ldglite
user$ make -f makefile.linux && echo OK
OK
There is a small risk that you may run into errors at this point, if
your system lacks some libraries. These errors will probably be of the
form .../bin/ld: cannot find -lX11. If you don't know how to
handle this, please contact an experienced Linux system
administrator.
user$ su
Password:
root# chown root.root l3glite l3gledit ldglite readme.txt
root# mv l3glite l3gledit ldglite /usr/local/bin
root# mv readme.txt /usr/local/share/ldraw/ldglite.readme
root# exit
exit
user$ cd ..
user$ rm -rf ldglite
Now you should be ready to run LDGLite - as the command ldglite - but
since the LDraw library has been placed differently from what LDGLite
expects, you have to set the environment variable LDRAWDIR to that
directory (/usr/local/share/ldraw). You can do that in your runtime
configuration scripts, just before you run ldglite, or you can create a
script that sets LDRAWDIR and then calls ldglite. I have chosen the last
of these three solutions (where I also make sure that there is no limits
on the stack size):
user$ su
Password:
root# cat > /usr/local/bin/ldglite-run << THE-END
? #!/bin/tcsh
? setenv LDRAWDIR /usr/local/share/ldraw
? limit stacksize unlimited
? /usr/local/bin/ldglite \$*
? THE-END
root# chmod a+x /usr/local/bin/ldglite-run
root# cat >> /etc/mailcap << THE-END
? application/x-ldraw;/usr/local/bin/ldglite-run -mc %s
? application/x-multi-part-ldraw;/usr/local/bin/ldglite-run -mc %s
? THE-END
root# exit
exit
user$
Step 4 (latest update 2002-05-23):
Now your browser should be ready to open LEGO building instructions
directly in LDGLite, when you click on links to them on the internet. You
can test it by clicking on tux.dat,
which should open a window with building instructions for a penguin (Tux,
the mascot of Linux). You may have to restart your browser to make it
recognise the existence of LDGLite.
Step 5:
There are currently two ways to create LEGO building instructions on
your computer. You can either write/edit the raw text LDraw files or you
can use an interactive drawing program, where you can move pieces around
on the screen. If you chose the former method, you should just use your
usual text editor and skip this step. If you would like to try the latter
method, you should install the program LeoCAD.
LeoCAD
LeoCAD is a great 3D editor for Linux (and Windows) which has offered
several improvements to the straight LDraw .dat format. It supports some
basic animation (via keyframing) and can also export to 3DStudioMax,
POV-Ray, and Alias Wavefront.
To compile: (last update 2006-01-06)
user$ svn co http://svn.gerf.org/svn/leocad/tags/leocad-0-74 leocad
user$ cd leocad
user$ make
user# strip bin/leocad
user$ su -
Password:
root# cp bin/leocad /usr/local/bin/
LeoCAD has different part database, what is available at http://www.leocad.org/files
root# cd /tmp
root# wget http://www.leocad.org/files/pieces.zip
root# wget http://www.leocad.org/files/update18.zip
root# mkdir /usr/local/share/leocad
root# cd /usr/local/share/leocad
root# unzip /tmp/pieces.zip
root# unzip /tmp/update18.zip
root#
root# leocad -l /usr/local/share/leocad
Step 6:
Dive In!
Learning how to use your new editor or understanding the LDraw file
format may be a challenge, but with a little practice you will get the
hang of it. The LeoCAD
Manual by Leonardo Zide will help you getting started.
Step 7:
Introduction to LDraw
Utilities
There is a lot you can do with LDraw files beyond just creating LEGO
models! Many contributors have developed utilities to make the most of
the LDraw file format. Check out a brief introduction to a few utilities,
and then move on to download them.
Step 8:
Download Software
Check out LDraw.org's (incomplete) list of software packages to
download which supplement the standard editors. Download programs like
L3P, POV-Ray, various file format converters and rendering tools.
Help!
Need help with any of this? Check out LDraw.org's Help Section,
or check out the Lugnet CAD
discussion groups and ask a large group of users for help.
