Support our host
News
Software
Reference
Community
Parts Library
About Us
Reference > Tutorials
Published By OrionP on Tuesday, September 09, 2003 - 03:15 AM
Printer-friendly page
By: Ahui Herrera
Page 1 | Page 2 | Page 3
This tutorial will assume that the reader knows how to create 3D still models using the LDraw system of tools. Additional information of the software talked about in this article can been obtained in the appendix. Furthermore, the reader may wish to download the following files to help them when going through the tutorial.
There are four basic steps to creating animations.
  1. Planning or creating storyboards
  2. Creating a 3D still model
  3. Rendering the 3D model
  4. Creating a video file of the animation
Step 1:
Storyboard 1 Storyboard 2
Storyboard 3 Storyboard 4
Before touching the computer, one must have an idea of what the final animation should look like. At the basic level a series of rough sketches on paper showing the major transitions or changes in the animation. In this tutorial we will be making a train engine move across the screen from right to left. Below you can see the storyboard for our animation project.
As you can see the first board shows nothing moving just a static background that will be in the entire animation. The 2nd board shows the introduction of the train engine and the direction it will go. The 3rd board appears to be the same as the 2nd but has been added because the engine will make a stop halfway through the screen. Since this is a change in the animation it should have it’s own storyboard. The 4th board shows that the engine is about to leave the screen from the left hand side.
Note that these storyboards are very, very crude. One does not need to be a professional artist to create storyboards. The whole purpose of the storyboards are to show the major changes in the animations (stop, go, turns, etc.) During the rendering Step these critical changes will become key stops/go for the rendering. It is much easier to catch mistakes during the production of storyboards than after you have spent 10+ hours rendering only to find out that you forgot a major event and must re-render and spend another 10+ hours.
Step 2:
Create a still 3D model
The final result from this Step is the conversion of the .ldr file into a .pov file. Note that if you use L3P Add-On to do the conversion use only the following switches:
-bu (bumps)
-sw (seam Width) .05
-q (Quality Level) 2
-o (Overwrite existing .POV)
By default L3P Add-on uses the cg camera Globe Position, -lg (light Globe Posotion) and adds a floor. Remove these options as the camera, lights and floor will be hand coded in step 3.
Note: Modified 30-Jan-04 by Orion
Recipient 2007
Kevin Clague
Current Contest Winners
Model of the Month
Scene of the Month
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: Opinions needed for Color and Edge Values
by Michael Heidemann - 33 minutes ago
by Scott Wardlaw - 52 minutes ago
by Willy Tschager - 1 hour ago
by Anders Isaksson - 2 hours ago
There are 30 unlogged users and 0 registered users online.
 Log in Problems?
 New User? Sign Up!
