The 2007/2008 LDraw Standard Committee (LSC) comprises Travis Cobbs [4], Michael Heidemann [5], William Howard [6], Philippe Hurbain [7] and Orion Pobursky [8]
Any vote is approved/rejected by a simple majority of 3 votes.
This is a list of issues the 2007/2008 LDraw Standard Committee (LSC) has voted on: (most recent first)
- 2008-05-31 Ratified LDraw.org File Format Restrictions for Official Parts [9] document.
- 2008-05-19 Agreed to allow sticker shortcuts, and came up with the naming convention. This information will be in the (not yet ratified) file format restrictions for official parts document.
- 2008-01-15 Agreed minor edit to the Official Library Header specification [10]
The 2006/2007 LDraw Standard Committee (LSC) comprises Travis Cobbs, Ross Crawford [11], Lars C Hassing, William Howard and Guy Vivan.
This is a list of issues the 2006/2007 LDraw Standard Committee (LSC) has voted on: (most recent first)
- 2007-09-23 Approved version 1.0 of the LDraw File Format specification [12]
- 2007-09-06 Approved proposal to allow zero or more qualifiers in the !LDRAW_ORG meta-command
- 2007-09-06 Rejected proposal to allow one optional qualifier in the !LDRAW_ORG meta-command
- 2007-07-10 Approved Version 1.4 of the Category and Keyword specification [13].
- 2007-03-07 Voted on proposal to make "Unofficial" directory an official location for unofficial parts. Proposal was rejected (voted down).
- 2007-02-21 Added description of using " (needs work)" in the part title to allow for parts to be certified with known problems.
- 2006-11-09 Approved Version 1.0 of the Back Face Culling (BFC) specification. The BFC spec can be found at here [14].
- 2006-10-12 Adopted the "de-facto" BFC extension as the official draft specification.
- 2006-10-02 Approved new parts header format of the "~Moved to" files to support the Contributor Agreement [15]. See Appendix II of the main file header article.
- 2006-09-29 Approved a format of the !LDRAW_ORG meta-statement suitable for the LDraw Parts Tracker. See Appendix I of the main file header article.
- 2006-09-08 Approved a new LDraw file header to support the Contributor Agreement [16]. The new header format can be found at here [17].
Related discussions and prior decisions can be found in the the LSC Archives [18]
Any current "work in progress" can usually be found on the LSC Scratch Pad [19]
Other topics/ideas that the LSC are considering/discussion are summarised below (in no particular order).
- Internationalisation of the part library
- Updating the policies for part votes
- Reference parser for LDraw 1.0 spec files
- An XML version of the specs
- Number that has to be used for Sticker
- Define rules for second Author
This list is not meant to be exhausive or restrictive.
Note:
Last edited by Travis Cobbs [20], 2008-05-31 - Added ldraw part restrictions document.
