Standard [1]: LDraw.org Official Library Specification for Sticker Parts [2]
Posted by : OrionP on Nov 28, 2004 - 01:13 AM
referenceSpecs [3]
Maintained by: The LDraw.org Standards Committee
Revision: 2.2, 24-Nov-04
The sticker is a 0.25 LDU thin box (or whatever shape sticker is in), oriented such that the top face is at -0.25 Y and parallel with the X-Z plane. The pattern is on the top face; the other (five) sides of the box correspond to background color of the sticker pattern (i.e. the color of the paper on which the sticker is printed, usually white).
Since it is unnecessary to emphasize edge of a sticker, the box should have no edge lines (linetype 2).
The sticker pattern is modeled by real colors, they are not modifiable from the outside, and so the use of color numbers 16 and 24 is not allowed.
The name of the part begins with 'Sticker ...'
The part number for the sticker file is the SKU from the edge of the sticker sheet suffixed with a single letter. Each sticker from a single sheet should have a unique suffix. If the entire sheet is modelled in one part file then use the SKU with no suffix. If the SKU is unknown then the part number is "sXXX" where "XXX" is a number assigned by the Parts Tracker admin.
Note: This document is an offical LSC specification and/or language extension. Material changes can only be made after ratification by the LSC.
