©2003-2006 LDraw.org
Standard [1]: LDraw.org Colour Definition Language Extension [2]
Posted by : OrionP on May 30, 2004 - 11:34 PM
referenceSpecs [3]
Maintained by: The LDraw.org Standards Committee
Writer: Steve Bliss, Tim Gould
Revision: 4, 28-April-07
This meta-statement will specify the properties of a single LDraw colour code. This statement may appear at any time in an LDR file, but will probably be most useful in the file header.
In official LDraw.org materials, !COLOUR will appear in the ldconfig.ldr configuration file, to define the standard LDraw color set. It will not appear in any official part or primitive files.
The current version of ldconfig.ldr can be found here [4]
Scope
It's recommended that colour definitions be limited in scope. A color definition will affect colors from the point it first appears, continuing through the end of the file. Commands preceding a colour definition will not be affected by the definition. Color definitions will expire at the end of the file in which they appear, effectively falling out of scope. Color definitions will be passed to subfiles.
The configuration file, ldconfig.ldr, is not affected by the scoping rules, in the sense that the definitions in ldconfig.ldr remain in effect after the renderer is finished processing ldconfig.ldr.
Syntax
The entire statement must appear on one line. It may be line-wrapped in this document for clarity.
0 !COLOUR name CODE x VALUE v EDGE e [ALPHA a] [LUMINANCE l] [ CHROME | PEARLESCENT | RUBBER | MATTE_METALLIC | METAL | MATERIAL <params> ]</params>
Tags. CODE, VALUE, EDGE, ALPHA, DITHER, LUMINANCE, CHROME, PEARLESCENT, RUBBER, MATTE_METALLIC, METAL and MATERIAL are keyword tags. Some tags are followed by a single parameter value. Tags are case-insensitive. Numeric parameters, other than RGB color values, should be specified in decimal. RGB values must be specified in hexidecimal, and must be prefixed with # or 0x. Byte values are integers in the range 0-255. Identifiers are strings of text. The allowable characters are alphanumerics from 7-bit ASCII set: a-zA-Z0-9_. Additionally, the first character in an identifier must an alphabetic (a-zA-Z). Identifiers are case-insensitive.
Definitions of Parameters
Only one of CHROME, PEARLESCENT, RUBBER, MATTE_METALLIC, METAL and MATERIAL may be specified for a single color. They all specify the finish/texture to be applied to an object being rendered. Other finish-tags may be defined over time.
Note: This document is an offical LSC specification and/or language extension. Material changes can only be made after ratification by the LSC.
Links
  [1] http://www.ldraw.org/index.php?name=News&catid=13
  [2] http://www.ldraw.org/index.php?name=News&file=article&sid=299
  [3] http://www.ldraw.org/index.php?name=News&catid=&topic=13
  [4] http://www.ldraw.org/library/official/ldconfig.ldr
