Maintained by: The LDraw.org Standards Committee
Author: The LDraw.org Standards Committee
Writers: Steve Bliss, Orion Pobursky [4], Willy Tschager [5], William Howard [6]
Contributors: Many
Table of Contents
Purpose [7]
LDraw Files [8]
The LDraw Co-ordinate System [9]
The LDraw Unit (LDU) [10]
Line Types [11]
Line Type 0 [12] - Comment or META Command
Line Type 1 [13] - Sub-file reference
Line Type 2 [14] - Line
Line Type 3 [15] - Triangle
Line Type 4 [16] - Quadrilateral
Line Type 5 [17] - Optional Line
Colours [18]
META Commands [19]
Header Statements [20]
Step [21]
Write/Print [22]
Clear [23]
Pause [24]
Save [25]
File Type [26] (LDRAW_ORG and variations)
CATEGORY and KEYWORDS [27]
MPD Statements [28]
BFC Statements [29]
Unofficial META Commands [30]
Adding New META Commands [31]
Purpose
Describing LEGO® bricks and models in a virtual environment is a challenging prospect. In 1995 James Jessiman developed just such a system with his LDraw program and file format. Since then the LDraw file format has grown to be the standard by which most create LEGO® models on the computer.
The aim of this document is to compile and consolidate James’s original file specification with selected additions made since.
LDraw Files
Every line of the file contains one command. With few exceptions, every command is independent of other lines. The exceptions are the BFC meta-commands which modify the behaviour of one or more following command lines. There is no line length restriction. The whitespace characters allowed for keyword and parameter separation include spaces and tabs. Every command starts with a number, called a line type. The function and format of the line is determined by the line type.
LDraw uses a right-handed co-ordinate system where -Y is "up".
LDraw parts are measured in LDraw Units (LDU)
Real World Approximations
1 LDU = 1/64 in
1 LDU = .4 mm
Notes: These real world approximations are just that: approximations.
While they can be used for determiming the LDraw equivalent of a portion of a physical part
(for example, the curve of a surface), key points on such portions should be verified by reference
to interactions with real parts. For example, it is usually possible to build a framework of
bricks and plates to "hug" the curve and act as reference points. When using these dimensions to
determine a pattern they should only be used for small areas/detail. Large areas should be measured
in multiples of plate/brick dimensions with any "left-over" being converted with the above approximations.
Line Types
The line type of a line is the first number on the line. The line types are:
If the line type of the command is invalid, the line is ignored.
Line Type 0
Line type 0 has two uses. One use is a comment the other is as a META command.
If the first line of a file is a line type 0 the remainder of the line is considered the file title (see Library Header specification [32]). This overrides any META commands on that line.
0 // <comment>0 <comment>Where:
<comment> is any string
The form 0 // <comment> is preferred as the // marker clearly
indicates that the line is a comment, thereby permitting parsers to stop processing the line.
The form 0 <comment> is deprecated.
META Commands
A META command is a statement used to tell an LDraw compatible program to do something. There are currently many official META commands [33] and even more unofficial META commands [34]. In a META command, a keyword follows the line type in the line. The keyword must be in all caps. The generic META line format is:
0 !<META command> <additional parameters>
Where:
! is used to positively identify this as a META command. (Note: A few official
meta commands do not start with a ! in order to preserve backwards compatibility, however, all
new official META commands must start with a ! and it is strongly recommended that new unofficial
meta-commands also start with a !)<META command> is any string in all caps<additional parameters> is any string. Note that if a META command does
not require any additional parameter, none should be given.
For a list of official META commands, see the META commands [35] section.
For a list of unofficial META commands, see the unofficial META commands [36] article.
Line Type 1
Line type 1 is a sub-file reference. The generic format is:
1 <colour> x y z a b c d e f g h i <file>
Where:
<colour> is a number representing the colour of the part.
See the Colours section [37] for allowable colour numbers.x y z is the x y z coordinate of the parta b c d e f g h i is a top left 3x3 matrix of a standard 4x4 homogeneous transformation matrix.
This represents the rotation and scaling of the part. The entire 4x4 3D transformation matrix would then
take either of the following forms:
/ a d g 0 \ / a b c x \ | b e h 0 | | d e f y | | c f i 0 | | g h i z | \ x y z 1 / \ 0 0 0 1 /The above two forms are essentially equivalent, but note the location of the transformation portion (x, y, z) relative to the other terms.
u' = a*u + b*v + c*w + x v' = d*u + e*v + f*w + y w' = g*u + h*v + i*w + z
<file> is the filename of the sub-file referenced and must be a valid LDraw filename [38].
Line type 1 should never use the colour 24.
(The complement colour is neither unique nor symmetric. The complement of the complement
of colour X is not necessarily colour X. Using colour 24 for line type 1 will therefore lead to
unexpected/undefined results.)
Sub-files can be located in the LDRAW\PARTS sub-directory, the LDRAW\P sub-directory, the LDRAW\MODELS sub-directory, the current file’s directory, a path relative to one of these directories, or a full path may be specified. Sub-parts are typically stored in the LDRAW\PARTS\S sub-directory and so are referenced as s\subpart.dat, while hi-res primitives are stored in the LDRAW\P\48 sub-directory and so referenced as 48\hires.dat
While there is no specified limit on how deep sub-files may be nested, there are probably practical limitations imposed by individual software programs.
There are many on-line references about transformation matrices, one such reference is The POV-RAY Matrix Page [39]
Line Type 2
Line type 2 is a line drawn between two points. The generic format is:
2 <colour> x1 y1 z1 x2 y2 z2
Where:
<colour> is a number representing the colour of the part,
typically this is 24 - the edge colour.
See the Colours section [40] for allowable colour numbers.x1 y1 z1 is the coordinate of the first pointx2 y2 z2 is the coordinate of the second pointLine type 2 (and also 5) is typically used to edge parts. When used in this manner colour 24 must be used for the line. Line type 2 can also be used to represent fine detail in patterns (cf some torso patterns) and when used in this manner any colour may be used for the line. In either case it should be remembered that not all renderers display line types 2 and 5
Line Type 3
Line type 3 is a filled triangle drawn between three points. The generic format is:
3 <colour> x1 y1 z1 x2 y2 z2 x3 y3 z3
Where:
See the Colours section [41] for allowable colour numbers.x1 y1 z1 is the coordinate of the first pointx2 y2 z2 is the coordinate of the second pointx3 y3 z3 is the coordinate of the third pointSee also the comments about polygons at the end of the Line Type 4 section.
Line Type 4
Line type 4 is a filled quadrilateral (also known as a "quad") drawn between four points. The generic format is:
4 <colour> x1 y1 z1 x2 y2 z2 x3 y3 z3 x4 y4 z4
Where:
See the Colours section [42] for allowable colour numbers.x1 y1 z1 is the coordinate of the first pointx2 y2 z2 is the coordinate of the second pointx3 y3 z3 is the coordinate of the third pointx4 y4 z4 is the coordinate of the fourth pointWhile no specific order (winding) is required, the points of the quadrilateral must be declared in either a clockwise (CW) or counter-clockwise (CCW) order (see BFC statements [43]). The "good" example exhibits clockwise winding. If the points were given in the order 1, 4, 3, 2, they would exhibit counter-clockwise winding and also be considered as "good". The "bad" example illustrates a "bow-tie" or "hour-glass" quad.
The four points must lie within a plane. Quads should not contain three co-linear points (they should be reduced to a triangle). Quads must not be concave (two or more other polygons must be used instead).
Co-planar polygons (line types 3 and 4) may overlap only if they are the same colour. Any such overlap must be kept to a minimum as it affects the render quality of transparent parts.
Polygons may intersect, but any such intersection must be kept to a minimum as it affects the render quality of transparent parts.
Where possible, abutting polygons should share common verticies. That is, if polygons ABCD and EGF
abut along the line AEFB, A and E should be the same point and F and B should be the same point.
[If A and E are the same point but F and B are not the same point, the pixel approximations of
lines A'B' and A'F' (where A' represents the pixel point of A - which will be subject to integer
truncation) may not be the same along the length A'F'. This will result in holes being visible in the
part, especially at high magnification/resolution, and is the primary cause of "dot creep" when
rotating parts.]
Where practical, if A and E (and/or F and B) are not the same point, one or other or both of the polygons
should be decomposed into two or more smaller polygons such that they share common verticies.
In the diagram, ABCD has been decomposed into the quad AFCD and the tri FBC
It is strongly recommended that polygons do not use colour 24 (the complement colour).Line Type 5
Line type 5 is an optional line. The generic format is:
5 <colour> x1 y1 z1 x2 y2 z2 x3 y3 z3 x4 y4 z4
Where:
See the Colours section [44] for allowable colour numbers.x1 y1 z1 is the coordinate of the first pointx2 y2 z2 is the coordinate of the second pointx3 y3 z3 is the coordinate of the first control pointx4 y4 z4 is the coordinate of the second control pointWith an optional line, a line between the first two points will only be drawn if the projections of the last two points (the control points) onto the screen are on the same side of an imaginary line through the projections of the first two points onto the screen.
The optional line can be a difficult concept to grasp. The best way to demonstrate how they work is through a picture.
5 24 Bx By Bz Ex Ey Ez Ax Ay Az Cx Cy Cz
A and C are on the same side of the green line through BE, so BE is drawn.
5 24 Cx Cy Cz Fx Fy Fz Bx By Bz Dx Dy Dz
B and D are not on the same side of the red line through CF, so CF is not drawn.
This serves to "outline" the edges of the curved surface, which is the intent of
optional lines.
As seen above, the control points usually can be choosen from
already known points in the object. Since they are never drawn, they can be
located anywhere, as long as they have the right controlling properties.
See also the colour comments at the end of the Line Type 2 section.
Colours
The official colours are defined via Colour Definition statements in the ldconfig.ldr file
See the LDraw.org Colour Definition Language Extension [45] for a description
of the Colour Definition Meta statement
The colour numbers 16 and 24 are reserved and must not be used in Colour Definition statements.
Colour 16
Colour 16 is referred to as the "main colour" or "current colour". When a sub-file is referenced
by another file all the colour 16 command lines are displayed using the colour of the line that
referenced it.
Example:
1 4 0 0 0 1 0 0 0 1 0 0 0 1 part.dat
All the colour 16 command lines in part.dat will be displayed using colour 4
Colour 24
Colour 24 is referred to as the "complement colour" or "edge colour". Colour 24 is most commonly
used for line types 2 (line) and 5 (optional line). When a sub-file is referenced by another file
all the colour 24 command lines are displayed using the complement colour of the line that referenced
it. The complement colour of a given colour is defined in the Colour Definition for that colour.
Example:
All the colour 24 command lines in part.dat will be displayed using the complement colour of colour 4
Use of colour 24 for line types other than 2 and 5 is strongly discouraged.
See the LDraw Colour Chart [46] for a complete list of the LDraw
colour number equivalents to the official LEGO colours.
META Commands
Meta commands (or meta statements) are a powerful way to extend the File Format Specification to enable the inclusion of meta data (such as author name, keywords, category, etc) and processing instructions (such as step, bfc, etc) within the data file. (See also List of Official META Commands [47])
For historical reasons, the original meta commands are defined as part of the file format specification, while others are defined in seperate language extension documents.
Header Statements
See the Official Library Header Specification [48]
Step
Marks the end of a building step
0 STEP
The Step command causes the original LDraw program to pause
until the Enter key is pressed.
Additionally a bitmap of the currently displayed parts in the model is saved to the
LDRAW\BITMAP directory. Therefore, for the original LDraw program, 0 STEP
is shorthand for 0 SAVE followed by 0 PAUSE
Other programs may interpret this META command differently.
Write/Print
Displays a message
0 WRITE <message>0 PRINT <message>
<message> is a string of any length.
The Write or Print commands cause the original LDraw program to display a message to the screen. This message is not saved on any bitmaps.
Clear
Clears the screen
0 CLEARThis command causes all previous drawn sub-files and line types to be cleared (erased). Any following line types are drawn as normal.
Pause
Pauses the drawing of a file
0 PAUSEThis command stops the further parsing of lines until the Enter key is pressed. Unlike the Step command, Pause does not save a bitmap of the currently displayed model to the LDRAW\BITMAP directory.
Save
Saves a bitmap of the current drawing
0 SAVESaves a bitmap of the current drawing in the LDRAW\BITMAP directory. Unlike the Step command, this command does not cause the program to pause.
File Type
Indicates the type of file (model, part, etc), and if it is part of the LDraw.org Parts Library.
0 !LDRAW_ORG <type> (qualifier(s)) (update-tag)0 LDRAW_ORG <type> update-tag0 Official LCAD <type> update-tag0 Unofficial <type>0 Un-official <type>
The first format (!LDRAW_ORG) is the current standard for files in
the official parts library. Older files still carry the second and third
(Official LCAD) formats. The valid values for the <type> field are:
* = values currently in use for official part files [49].
- = only used in unofficial files
+ = obsolete/deprecated, still appears on some files.
Some older official files do not include a type code on their File Type line. Unofficial files may have a variety of values after the initial tag. The exact format of the File Type line has changed over time. In general, parsers should consider this line to be case-insensitive and free-format.
CATEGORY and KEYWORDS Statements
See the CATEGORY and KEYWORDS Language Extension [50]
MPD Statements
See the MPD Language Extension [51]
BFC Statements
See the LDraw Language Extension for Back Face Culling (BFC) [52]
See the list of known META commands and the programs that use them [53]Adding New META Commands
The following guidelines should be followed by developers when adding new META command functionality to their LDraw.org compatible programs:
0 !LDPARSER EXAMPLE
