These instructions assume you have some tools installed on your system. Here is a list:
wget [3]wget installed with the
command:
wget --versionIf you don't have it, you may download it from http://wget.sunsite.dk/ [4].
perl --versionIf you don't have it, you may download it from http://www.perl.org/ [6].
bzip2 [7]bzip2 installed with the
command:
bzip2 --versionIf you don't have it, you may download it from http://sources.redhat.com/bzip2/ [8].
gcc and make)
to translate the programs to executable form. These tools usually come
in the "development" section of your Linux distribution.Download and install the LDraw Parts Library.
user$ cd /tmp user$ wget http://www.ldraw.org/files/unix-complete.tgz [10] ... user$ su - Password: root# cd /usr/local/share/ root# tar xzf /tmp/unix-complete.tgz && echo OK ... OK root# mkdir -p ldraw/bitmap root# chmod a+w ldraw/bitmap root# chown -R root.root ldraw root# exit exit user$Step 2 (latest update 2006-01-06):
To view ldraw model use LDView [11]. You can install RPM or tar.gz version (available on sf.net [12]), or build from source.
To install LDView3.tgz (root permission is not required):
user$ tar zxvf LDView3.tgz user$ cd LDView3 user$ ./LDView
To install from RPM (root privilege is required):
root# rpm -i ldview-3.0-1.i386.rpm
To build from source:
user$ su - root# cvs -z3 -d:pserver:anonymous@cvs.sourceforge.net/cvsroot/ldview co LDView root# cd LDView/QT root# ./makeall root# make install root# exit user$ LDViewStep 3 (latest update 2002-05-23):
Install LDGLite. LDGLite is a rather
efficient tool for showing building instructions "on the fly", when you
download them as ".dat", ".ldr" or
".mpd" files from the web.
user$ cd /tmp user$ wget http://ldglite.sourceforge.net/ldglitesrc0_9_5.zip [13] ... user$ unzip -uoa ldglitesrc0_9_5.zip ... user$ cd ldglite user$ make -f makefile.linux && echo OK ... OK
There is a small risk that you may run into errors at this point, if
your system lacks some libraries. These errors will probably be of the
form .../bin/ld: cannot find -lX11. If you don't know how to
handle this, please contact an experienced Linux system
administrator.
user$ su Password: root# chown root.root l3glite l3gledit ldglite readme.txt root# mv l3glite l3gledit ldglite /usr/local/bin root# mv readme.txt /usr/local/share/ldraw/ldglite.readme root# exit exit user$ cd .. user$ rm -rf ldglite
Now you should be ready to run LDGLite - as the command ldglite - but since the LDraw library has been placed differently from what LDGLite expects, you have to set the environment variable LDRAWDIR to that directory (/usr/local/share/ldraw). You can do that in your runtime configuration scripts, just before you run ldglite, or you can create a script that sets LDRAWDIR and then calls ldglite. I have chosen the last of these three solutions (where I also make sure that there is no limits on the stack size):
user$ su Password: root# cat > /usr/local/bin/ldglite-run << THE-END ? #!/bin/tcsh ? setenv LDRAWDIR /usr/local/share/ldraw ? limit stacksize unlimited ? /usr/local/bin/ldglite \$* ? THE-END root# chmod a+x /usr/local/bin/ldglite-run root# cat >> /etc/mailcap << THE-END ? application/x-ldraw;/usr/local/bin/ldglite-run -mc %s ? application/x-multi-part-ldraw;/usr/local/bin/ldglite-run -mc %s ? THE-END root# exit exit user$Step 4 (latest update 2002-05-23):
Now your browser should be ready to open LEGO building instructions directly in LDGLite, when you click on links to them on the internet. You can test it by clicking on tux.dat [14], which should open a window with building instructions for a penguin (Tux, the mascot of Linux). You may have to restart your browser to make it recognise the existence of LDGLite.
Step 5:There are currently two ways to create LEGO building instructions on your computer. You can either write/edit the raw text LDraw files or you can use an interactive drawing program, where you can move pieces around on the screen. If you chose the former method, you should just use your usual text editor and skip this step. If you would like to try the latter method, you should install the program LeoCAD.
LeoCAD
LeoCAD is a great 3D editor for Linux (and Windows) which has offered several improvements to the straight LDraw .dat format. It supports some basic animation (via keyframing) and can also export to 3DStudioMax, POV-Ray, and Alias Wavefront.
To compile: (last update 2006-01-06)
user$ svn co http://svn.gerf.org/svn/leocad/tags/leocad-0-74 leocad user$ cd leocad user$ make user# strip bin/leocad user$ su - Password: root# cp bin/leocad /usr/local/bin/
LeoCAD has different part database, what is available at http://www.leocad.org/files [15]
root# cd /tmp root# wget http://www.leocad.org/files/pieces.zip [16] root# wget http://www.leocad.org/files/update18.zip [17] root# mkdir /usr/local/share/leocad root# cd /usr/local/share/leocad root# unzip /tmp/pieces.zip root# unzip /tmp/update18.zip root# root# leocad -l /usr/local/share/leocadStep 6:
Dive In!
Learning how to use your new editor or understanding the LDraw file
format may be a challenge, but with a little practice you will get the
hang of it. The LeoCAD
Manual by Leonardo Zide will help you getting started.
There is a lot you can do with LDraw files beyond just creating LEGO models! Many contributors have developed utilities to make the most of the LDraw file format. Check out a brief introduction to a few utilities, and then move on to download them.
Step 8: Download Software [18]Check out LDraw.org's (incomplete) list of software packages to download which supplement the standard editors. Download programs like L3P, POV-Ray, various file format converters and rendering tools.
Help!Need help with any of this? Check out LDraw.org's Help Section [19], or check out the Lugnet CAD [20] discussion groups and ask a large group of users for help.
Note: Thanks to Peter Bartfai for updating these instructions
