This section will help you set up the files you need to get started with LDraw. The installation process is not complicated, but it does require a working knowledge of computers.
Step 1:
Download and install original LDraw Package
The original LDraw package contains the parts libraries needed to get started creating LDraw models This step cannot be skipped.
Step 2:
Download Bricksmith
Bricksmith
Bricksmith is a full-featured model editor for Mac OS X 10.3 or later. Bricksmith provides a spinnable 3D model view, a fast, comprehensive part browser, easy access to the full color palette, and inspectors to tweak part components. It also supports submodels (MPD), steps, and primitives, as well as the usual features you expect in a Mac application (undo, copying, scrolling, and drag-and-drop reordering of file contents). And it is open source.
To download, visit the Bricksmith site, click the download link at the top of the page. Note: the Bricksmith site distributes a version of Bricksmith that includes an LDraw parts library. If you followed step 1, be aware you do not need to download another parts library.
Step 3:
Dive in!
Learning how to use your new editor may be a challenge, but with a little practice you will get the hang of it.
Step 4:
Introduction to LDraw Utilities
There is a lot you can do with LDraw files beyond just creating LEGO models! Many contributors have developed utilities to make the most of the LDraw file format. Learn about them here. Note: on the Mac, the only utilities are POV-Ray and L3P related.
Step 5:
Download Software
Check out LDraw.org's list of software packages to download which supplement the standard editors. Download programs like L3P or L3P Launcher, and POV-Ray. You can also convert LDraw files into Anton Raves' POV-Ray library format with Anton's POV-Ray converter.
Help!
Need help with any of this? Check out LDraw.org's Help Section, or check out the LDraw.org Forums and ask a large group of users for help.
