Support our host
News
Software
Reference
Community
Parts Library
About Us
Reference > Tutorials
Published By SharkD on Friday, September 25, 2009 - 06:31 AM
Printer-friendly page
LDraw models are great to look at, but are generally inappropriate for real-time rendering tasks such as video games. Here's why.
The main issue is detail. LDraw models are highly accurate representations of real Lego parts. Each part can have lots of minute details, and the number of parts in a single large model can be quite huge! This amount of detail translates into lots and lots of polygons, which is the main limiter of how well a real-time rendering application will run.
The second issue is hidden objects: LDraw models are made up of multiple smaller parts. These parts are assembled as they are, with no modification. Thus, all the inner bits and pieces (such as studs) that are visible when viewing the part by itself but invisible when viewing the entire model are still there. That means there's lots of detail (and thus polygons) in the model that will never see the light of day!
The third issue is redundancy: Let's take for example a model composed of two identical bricks stacked on top of each other. The bricks are flush with each other such that the bottom surface of the top object is pressed against the top surface of the bottom object. You could say that the objects occupy the same place, or are coincident. In reality, there's a tiny gap between these surfaces where a small amount of air can pass through. In computer modeling, however, it is often useful to disregard these differences and simply make all points and surfaces mathematically perfect. While this is trivial to do and can lead to pleasing results, it introduces a problem. Each part has a set of matching surfaces and vertices shared by the other part. Some of these surfaces and vertices are in fact duplicates. The duplicate elements no longer serve a useful purpose, and end up merely taking up much needed space in the model file. There's a strong need to get rid of these redundant, wasteful elements.
I know of two tentative, partially automated ways of addressing these issues that, when used in conjunction with each other, might eliminate the above problems: removing internal faces using MeshLab and using LDBoxer to convert parts to simpler, lighter versions. I will not discuss these in detail. They are, however, addressed in the links at the end of this article. Simple poly-reduction techniques such as Blender's "Decimate" operation will not work, as they choose polygons more or less randomly, and don't differentiate between the "inside" and "outside" of a model.
Note that there is an additional issue related to MeshLab's internal face reduction approach: back-face culling (BFC). When cleaning parts from a model, Meshlab requires that the vertices of the triangles be "wound" properly. Winding is what allows the program (and other programs that use 3D models) to determine the surface normal when not specifically defined, and thus (roughly) the "outside" and "inside" of the model. If the vertices are not wound properly, the program will get confused and behave improperly. Unfortunately, in the case of LDraw models only a small minority of parts have been validated as "BFC certified", and thus wound properly. This fact peculiar to LDraw models will likely make the approach untenable in the majority cases.
Links:
Note: Rephrased.
Recipient 2009
Tim Courtney
Current Contest Winners
Model of the Month
Scene of the Month
Part of the Month - Best Part
Part of the Month - Most Desired Part
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: The future of LDraw?
by Timothy Gould - 2 hours ago
by Orion Pobursky - 3 hours ago
by Dave Sterling - 4 hours ago
Re: number notation in official parts
by Anders Isaksson - 8 hours ago
There are 51 unlogged users and 0 registered users online.
 Log in Problems?
 New User? Sign Up!
©2003-2010 LDraw.org, see Legal Info for details.
