Support our host
News
Software
Reference
Community
Parts Library
About Us
Reference > Specifications
Published By OrionP on Friday, September 12, 2003 - 06:51 PM
Printer-friendly page
LCD - LDraw Connection Database Version 1.04
A Draft Idea for LEGO CAD Software Developers
By: Láng Attila D. (LAD) and Kiss Attila Csongor (KACS)
Contents
1. What is LCD?
1.1. What Can LCD Solve?
1.2. Notes and Abbreviations
2. The Database
2.1. The Idea
2.2. Connectors Connecting
2.3. Connector Properties
2.3.1. Standalone Properties
2.3.2. Connected Properties
2.4. Building the Database
3. The Connector Descripting Lists
4. At the End User
Appendix A: The LCD Database Draft
A1. Connectors
A2. Connections
Appendix B: CDL File Drafts
Appendix C: Additional Proposals
1. What is LCD?
LCD has nothing to do with Liquid Crystal Display: it is LDraw Connection Database. This is a proposal for developers of LEGO CAD softwares, such as MLCAD, LeoCAD etc. It is based on the LDraw .dat file system of parts.
LCD, if once realized, can solve problems of LEGO CAD software users of connecting parts correctly. When connecting virtual LEGO parts, it is possible to make two kinds of errors: either leaving a gap or pushing the parts inside each other. The correct distance between two parts may be hard to discover exactly, especially when working in three dimensions, for example, in complex Technic LEGO sets. Even if an experienced LEGO CAD builder can connect parts quickly, LCD may add some convenience to his or her work; and for beginners, it seems to be a must. And LCD can do more.
In this document, numbers like 3001 refer to numbers of LEGO parts, as registered in LEGO CAD softwares. When writing the document, we have used MLCAD 2.00 with the parts list from the archive complete.exe, downloaded from www.ldraw.org, archived at 30th September, 2000.
Abbreviations used in this document:
CDL -- Connector Descripting List.
A file accompanying each LEGO part file, containing information about connectors found on a specific part.
LCD -- LDraw Connection Database.
A file accompanying a LEGO CAD software, containing general connector and connection information. Also, the name of the whole idea.
LCS -- Local Coordinate System.
A three-dimensional coordinate system belonging to a specific type of connector.
All trademarks mentioned in this document are property of their respective owners.
2. The Database
2.1. The Idea
The idea is maintaining a connection database. It deals with "connectors", what is a term to group all particles what can connect to each other. The most important connector is the LEGO stud. All connectors are arranged to pairs, "what connects to what". We may call them as male and female, but sometimes this may be confusing. The "spouse" of the LEGO stud is a stud inlet created on the bottom of a basic LEGO brick. And finally, connectors may have variants: for example, 3062A and 3062B are the same parts, but 3062B has a hollow stud on it. The variant behaves like a normal connector, but may have some additional behaviors.
A draft example of the stud connector family:
Male:
Stud
variant:
Hollow Stud (e.g. 3062B)
Female:
Stud Inlet
When coding the properties of a connector, we specify:
  1. What connectors are suitable for the connector as a spouse? In the above example, the female Stud Inlet may connect to either a Stud or a Hollow Stud. Both male variants may connect to a Stud Inlet, but the Hollow Stud may, additionally, connect to an antenna or other rods.
  2. What is the position they take when connected? This is specified in a coordinate system.
  3. What movements can the connected pair make? This is specified in a coordinate system, by a range of degrees (or radians), according to each axis. For example, the Stud--Stud Inlet connection cannot move; other connections can slide and/or rotate.
LCD is a database what contains information about connectors and only connectors. There is nothing in it about any specific LEGO part. It describes connectors in a pseudo-physical context, not dealing with their visual appearance, focusing only to the question of connecting and, later, of moving compared to each other.
Some kinds of LEGO connectors for a first taste:
male:    Stud
            (connects to Stud Inlet)
   variant: Hollow Stud
              (connects to Stud Inlet, Rod)
   variant: Minifig Head Stud
              (connects to Stud Inlet, Minifig Cap)
   variant: Minifig Head Hollow Stud
              (connects to Stud Inlet, Minifig Cap, Rod)
female: Stud Inlet
           (connects to Stud and variants)
   variant: Turnable Stud Inlet
              (connects to Stud and variants) e.g. 3821
female: Minifig Cap
           (connects to Minifig Head Stud, Minifig Head Hollow Stud)
male:   Rod
           (connects to Hollow Stud, Minifig Head Hollow Stud,
            Minifig Hand)
male:   Pin
           (connects to Pinhole) e.g. 3673
   variant: Pin 3/4
              (connects to Pinhole) e.g. 32002
   variant: Pin 1/2
              (connects to Pinhole) e.g. 4274
female: Pinhole
           (connects to Pin and variants) e.g. 3700
male:    Axle
           (connects to Axlehole) e.g. 3704
female: Axlehole
           (connects to Axle) e.g. 32064
male:    Minifig Arm Top
           (connects to Minifig Torso)
female: Minifig Torso
           (connects to Minifig Arm Top)
male:    Minifig Wrist
           (connects to Minifig Arm Bottom)
female: Minifig Arm Bottom
           (connects to Minifig Wrist)
male:    Minifig Tool
           (connects to Minifig Hand) e.g. 38, 2561, 2562, 3852
female: Minifig Hand
           (connects to Minifig Tool)
male:    Towball
           (connects to Towball Socket) e.g. 3184
female: Towball Socket
           (connects to Towball) e.g. 3183
These examples show some interesting differences. A Minifig Head Stud is an absolutely normal stud, identical to any Stud in its physical appearence; however, if we'd identify it as a Stud, we'd fall into problems when taking any minifig headdress (3624, 3833, 3844, 3896, 4485 etc.). These parts have a normal Stud Inlet inside, but they cannot be connected to, say, a 3001 block. This will force us to make a distinction between a normal Stud and a Minifig Head Stud; the latter can connect to a Minifig Cap, the former cannot.
Some connectors are very specific. For example, there are only two minifig arms (975, 976) and one minifig hand (977) listed in the parts inventory, but we need a special connection pair to put them together, and another special connection is needed to connect the arm to the torso. Other connections are, on the other hand, very diversified, like the Stud family. Similarly, Minifig Tool is a group name for all parts (more exactly, for handles of all parts) that are designed to fit into a minifig's hand. For example, a Rod (the 3957 antenna) fits into a minifig's hand, so it is actually a Minifig Tool. But because it can be assembled into a 3062B hollow rounded block, we must make a distinction here, too. Rod is a "bachelor" connector, it hasn't any female spouse designed specifically for it, but it fits to several places. Such connectors will turn our full connector list into a cross-referencing database.
When will we be able to give the same code to two kinds of connectors, and when will be two different codes required? The answer is simple in theory: if the two connectors act in the same way physically, and if all spouses for the first connector are applicable to the second one and vice versa, we can treat them as identical. (This means that anything what can hold a Stud tight is a Stud Inlet, no matter how does it look like.) In practice, the answer is a little more difficult, since we have to hunt the whole database for possible exceptions; but for the first drafts of LCD, we may omit bizarre or rare applications, such as the antenna poked through a hollow round 1*1 block. This is a physical possibility, but probably not a used building practice. (Are we wrong here?)
A connector, observed as a standalone entity, has some properties; two connectors in a connected state have additional properties. We will refer these as standalone and connected properties.
The most important standalone property will be the Local Coordinate System (LCS). This is a three-dimensional coordinate system, having a base point and axes. We will use it to snap the two connectors together. For example, a Stud can be observed as a virtual disk with 8 mm of diameter, with an axis crossing its center. A Stud Inlet can be observed as a similar disk. If we position both base points to the same coordinates, and turn their axes to the same directions, we have connected the Stud and the Stud Inlet perfectly.
Another standalone property will be the Size property. We won't refer to each millimeter of an Axle as a separate connector, although an Axle may connect to several Axleholes. We treat its whole length as a single, large sized Axle connector. This helps us to move parts along the Axle. But this makes it necessary to keep more parts connect to the same connector, too.
Similarly, we won't refer to each Stud on the same surface separately. Instead, we treat them as a single, large sized Stud connector. This helps us to maintain special connections, like the Stud--Plate Edge connection (see Appendix A).
The Size property will be different for different parts; hence, it won't be stored in the LCD but in the CDL files (see below).
The most important connected property will be the Movement property: how can the connectors act together? We have to store the rules for this property for each pair of possible combinations; for example, we store (at least) two Movement properties for the Hollow Stud connector: one will be Hollow Stud with Stud Inlet and the other will be Hollow Stud with Rod.
The value of a Movement property can be one or more allowed rotations and slides.
A rotation is registered for the Stud--Turnable Stud Inlet connection: a Turnable Stud Inlet (like at the bottom of 3821 door) may turn around the vertical axis (vertical if studs pointing upwards) in 360 degrees. (The door itself may collide with the neighboring studs, if any, but this is a question being totally out of our interest.)
A slide is registered for the Axle--Axlehole connection: the Axlehole may slide along the main axis of the Axle, as long as the Axle is physically present.
Several rotations are registered for the Towball--Towball Socket connection: they may rotate freely around the center of the Towball, according to all three dimensions, up to a specified degree of difference.
And finally, both a rotation and a slide is registered for the Rod--Hollow Stud connection: the Hollow Stud may slide along the Rod and/or rotate around its axis.
Another connection property will be the Distance of Drag. This is a distance (in millimeters, maybe) from where the two connectors are recognized as a pair and being automatically fitted by the LEGO CAD software. For example, the height of a plate (1/3 brick) without the studs is 3.2 millimeters; it seems to be logical to set the distance of drag to be less than the half of this, so 1.5 mm. This is a lot less than half of the diameter of a stud and its surrounding area. If this value is set correctly, take two bricks and put them near each other -- in a distance of 1.6 mm between a Stud and a Stud Inlet. Nothing happens. Move them a little closer -- snap! The bricks fit correctly.
Why do we use less than the half? Take a 1x2 brick and put a 1x1 brick onto it, exactly positioning onto the center of the bigger brick. How will the software know where does the smaller brick belong to? There is an equal chance for both studs. If you set the distance to the half of the critical value, you will see the brick snapping to an arbitrarily chosen stud, what may make things messing up.
How to build the LDraw Connection Database? We have to take all virtually available LEGO parts and examine the ways of possible connections. We have to take notes on what do they connect to, how do they fit together, what movements can they make. For each connector type, we set up an LCS. For each possible connection, we set up Movement rules. (And, of course, we register properties not mentioned in this document but to be invented later.) We discover what connectors may be treated as the same and what are different. We assign a unique code to each connector type and variant.
Finally, we build a database (LCD) containing all required data, and publish the list of assigned codes with the necessary information.
After building the LCD, we have to use it. To do so, we have to register the actual connectors found on the surface (and, if necessary, in the interior) of the actual LEGO parts. For each .dat file describing a part, we create a Connector Descripting List (CDL). This file will describe:
  1. Where are connectors on the part and what are their Sizes
  2. What direction are they pointing to
  3. What type of connector are they each.
The position and direction of connectors on the part are specified in a coordinate system relative to the part, suitable for the general coordinate system used in LEGO CAD softwares. (Yet we didn't find a description for the .dat file format, so we can't talk about details; however, this document is intended to be read by LEGO CAD developers who already know this coordinate system much better than we do.) The type of connectors is coded according to the LCD database codes. For those locations on the part where no connector is there, we don't store any information.
For example, the standard 3001 brick will be described in 3001.cdl as follows (coordinates are specified here as stud and brick height units, what won't be useful for real, only used as an example):
Stud at x = 0, y = 0, z = 1; Size x = 2, y = 4
Stud Inlet at x = 0, y = 0, z = 0; Size x = 2, y = 4
We must be careful when looking for connectors. A fully equipped minifig will be a good example. Let's take a minifig wearing a helmet with a visor, an airtank, tools in his hands and a ski; disassemble him and take notes for all parts:
Part Connectors found
2446 Minifig Helmet Minifig Cap, Visor Holder
2447 Minifig Helmet Visor Visor
3626B Minifig Head -- Stud Hollow Minifig Head Hollow Stud, Stud Inlet
3838 Minifig Airtanks Minifig Neck Surround
973 Minifig Torso Stud, Minifig Neck, Minifig Torso (2), Stud Inlet (2)
975 Minifig Arm Right Minifig Arm Top, Minifig Arm Bottom
976 Minifig Arm Left Minifig Arm Top, Minifig Arm Bottom
977 Minifig Hand (2) Minifig Wrist, Minifig Hand
38 Minifig Harpoon Minifig Tool
4479 Minifig Metal Detector Minifig Tool, Stud (6), Stud Inlet
970 Minifig Hips Stud (2), Minifig Hips Left, Minifig Hips Right
971 Minifig Leg Right Minifig Leg Right, Stud Inlet
972 Minifig Leg Left Minifig Leg Left, Stud Inlet
6120 Minifig Ski (2) Stud, Stud Inlet, Hole (2)
Many of the listed connectors weren't mentioned previously in the document, but probably their meanings will be obvious.
Some questions may arise from this example. Why do we need separate Minifig Hips/Leg Left and Minifig Hips/Leg Right connector pairs? They both seem to be the same. This is true for their physical appearance, but not for their movement. If we set up the LCS around the rotator axle on the hips, what seems to be logical, we well see them rotating in opposite directions. If the legs could turn forwards as far as backwards, this wouldn't be a problem, but they cannot. The range of allowed movement will be the opposite of each other.
Of course, if the LCD system is once developed in reality and implemented in LEGO CAD softwares, designers of new parts should equip their creations with the appropriate .cdl files.
4. At the End User
But finally, what is this whole thing for? Who will take any advantage from it? The end user. Those people who use MLCAD, LeoCAD or other LEGO CAD software for building sets of virtual LEGO. When getting LCD-equipped software in their hands, they will see almost the same as previously, but there will be something more.
They take two parts near each other, and they fit. No need to position them neatly together, they will fit as in real plastic life. They can assemble a complete minifig on their own in some seconds, and they will be sure that all parts are really fitting together. They assemble a complicated Technic model almost as easily as they do it in real. But if they want to try something irregular, they can simply turn off LCD system as an option and go on their own.
When putting two parts near each other, the currently selected one will be moved to the connecting one, leaving the latter where it is.
When selecting and moving a part which is already connected to another part, either the selected part will move only, separating from the connecting part -- or both parts will move, and if the second one is connected to a third part, that will move, too, and so on. This is because when connecting parts, LCD system makes a note for itself telling that those parts are connected together, so it always knows what parts are building up a submodel. Now the user can take a submodel just like in reality, grabbing a part of it and the whole is moving. Or, the grabbed part may separate from the submodel. Which one will happen depends on a toggle that the user can set.
By keeping information of the way connections can rotate or slide, LCD system can put life into virtual LEGO models. When connecting parts, each movable connection is included in a special list. The user can view this list, disable items in it (in the case of unimportant or obstacled movements), make notes for the important items, and, most importantly, give orders to the items. Here is a hinge, rotate it! And it will be so. And user will see it is good. And user will call it LEGO. Evening and morning, seventh day.
Acrylnitrile butadiene styrene, the raw material for real LEGO bricks,moulds in a precision of 0.005 mm.
Light, the raw material for virtual LEGO bricks, moulds in a precision smaller than an atom.
We can take an advantage from this.
A1. Connectors
In this section, we will create a draft list for LEGO connectors. This is a simplified version of a real LCD database. We only list connectors and their most important properties. We didn't take a ruler and a protractor to discover actual size and angle information. Yet we don't establish LCS orientations. The purpose of this draft is only to show developers: what can they do and how they can do it.
The following format is used to describe connectors:
Stud
     Level:1
     Sample: 3001, top
     Spouse: Stud Inlet, Plate Edge
     Variant: Hollow Stud, Minifig Stud, Minifig Hollow Stud
Variants are listed separately, but only the differences from their ascendant are listed.
A new thing here is Level. This isn't a property and we needn't include it in a real LCD database. This is an information for developers on how important the connector is. Level 1 connectors are the most important, basic-level ones; an LCD system won't be usable before knowing all of these. Level 2 ones are less important, developers may omit them from first releases. Level 3 are unofficial, non-standard connectors.
The list is far from complete.
Stud
     Level: 1
     Sample: 3001, top
Hollow Stud
     Level: 2
     Sample: 3062B, top
     Spouse: Stud Inlet, Plate Edge, Rod
     Variant of: Stud
Minifig Head Stud
     Level: 2
     Sample: 3626A, top
     Spouse: Stud Inlet, Minifig Cap
     Variant of: Stud
     Level: 2
     Sample: 3626B, top
     Spouse: Stud Inlet, Minifig Cap, Rod
     Variant of: Stud
Stud Inlet
     Level: 1
     Sample: 3001, bottom
     Spouse: Stud and variants
     Variant: Turnable Stud Inlet
Turnable Stud Inlet
     Level: 1
     Sample: 3821, bottom
     Variant of: Stud Inlet
Minifig Cap
     Level: 2
     Sample: 3624
     Spouse: Minifig Head Stud, Minifig Head Hollow Stud
Shutter Holder
     Level: 2
     Sample: 3581
     Spouse: Shutter
Shutter
     Level: 2
     Sample: 3582
     Spouse: Shutter Holder
Pin
     Level: 2
     Sample: 2458
     Spouse: Hole
Axlehole
     Level: 2
     Sample: 3941
     Spouse: Axle
Axle
     Level: 2
     Sample: 3704
     Spouse: Axlehole
Metal Axle Holder
     Level: 2
     Sample: 3137
     Spouse: Metal Axle
Metal Axle
     Level: 2
     Sample: 35B
     Spouse: Metal Axle Holder, Wheel Town
Wheel Town
     Level: 2
     Sample: 3137C01
     Spouse: Metal Axle, Wheel Town Tyre
Wheel Town Tyre
     Level: 2
     Sample: 123
     Spouse: Wheel Town Tyre
Coupling Male
     Level: 2
     Sample: 4747
     Spouse: Coupling Female
Coupling Female
     Level: 2
     Sample: 4748
     Spouse: Coupling Male
Minifig Hand
     Level: 2
     Sample: 977, 4085
     Spouse: Minifig Tool, Plate Edge
Towball
     Level: 2
     Sample: 3184
     Spouse: Towball Socket
Towball Socket
     Level: 2
     Sample: 3183
     Spouse: Towball
Plate Edge
     Level: 3
     Sample: 3022
     Spouse: Stud, Minifig Hand
Hole
     Level: 2
     Sample: 6541
     Spouse: Pin
Gear Tooth
     Level: 2
     Sample: 741, 3647, 3743, 6589, 32270
     Spouse: Gear Tooth
Train Rail
     Level: 2
     Sample: 3228
     Spouse: Train Wheel
Train Wheel
     Level: 2
     Sample: 2879
     Spouse: Train Rail
     Level: 2
     Sample: 3838
     Spouse: Minifig Neck
Minifig Arm Top
     Level: 2
     Sample: 976
     Spouse: Minifig Torso
Minifig Tool
     Level: 2
     Sample: 2562
     Spouse: Minifig Hand
Visor Holder
     Level: 2
     Sample: 2446
     Spouse: Visor
Visor
     Level: 2
     Sample: 2447
     Spouse: Visor
Minifig Hips Left
     Level: 2
     Sample: 970
     Spouse: Minifig Leg Left
Minifig Hips Right
     Level: 2
     Sample: 970
     Spouse: Minifig Leg Right
Minifig Leg Left
     Level: 2
     Sample: 972
     Spouse: Minifig Hips Left
Minifig Leg Right
     Level: 2
     Sample: 971
     Spouse: Minifig Hips Right
Minifig Arm Bottom
     Level: 2
     Sample: 976
     Spouse: Minifig Wrist
Minifig Wrist
     Level: 2
     Sample: 977
     Spouse: Minifig Arm Bottom
Minifig Torso
     Level: 2
     Sample: 973
     Spouse: Minifig Arm Top
Two Fingers
     Level: 2
     Sample: 6048
     Spouse: Three Fingers
Three Fingers
     Level: 2
     Sample: 6217
     Spouse: Two Fingers
Cupboard Inlet
     Level: 2
     Sample: 4534
     Spouse: Cupboard Drawer
Cupboard Drawer
     Level: 2
     Sample: 4536
     Spouse: Cupboard Inlet
Light
     Level: 2
     Sample: 4767
     Spouse: Light Globe
Light Globe
     Level: 2
     Sample: 4773
     Spouse: Light
Hinge Base
     Level: 2
     Sample: 3937
     Spouse: Hinge Top
Hinge Top
     Level: 2
     Sample: 3938
     Spouse: Hinge Bottom
Hinge Female
     Level: 2
     Sample: 3831
     Spouse: Hinge Male
Hinge Male
     Level: 2
     Sample: 3830
     Spouse: Hinge Female
Car Roof
     Level: 2
     Sample: 4213
     Spouse: Car Roof Holder
Car Roof Holder
     Level: 2
     Sample: 4214
     Spouse: Car Roof
Magnet
     Level: 2
     Sample: 73092
     Spouse: Magnet, Magnet Holder
Magnet Holder
     Level: 2
     Sample: 2607
     Spouse: Magnet
Turntable Small Base
     Level: 2
     Sample: 3680
     Spouse: Turntable Small Top
Turntable Small Top
     Level: 2
     Sample: 3679
     Spouse: Turntable Small Base
Turntable Big Base
     Level: 2
     Sample: 3403
     Spouse: Turntable Big Top
Turntable Big Top
     Level: 2
     Sample: 3404
     Spouse: Turntable Big Base
A2. Connections
In this section, we will create a draft list for LEGO connections. This is a simplified version of a real LCD database. We only list connections and their most important properties. We didn't take a ruler and a protractor to discover actual size and angle information. Yet we don't establish LCS orientations. The purpose of this draft is only to show developers: what can they do and how they can do it.
The following format is used to describe connections:
Stud--Stud Inlet
     Level: 1
     Sample:
     Snap: each stud into an inlet
     Rotation: none
     Slide: none
Snap is a property describing how connectors will fit together; Rotation and Slide describe how do they act together once snapped. In an actual LCD database, all three properties are expressed in coordinate figures.
A new thing here is Level. This isn't a property and we needn't include it in a real LCD database. This is an information for developers on how important the connection is. Level 1 connections are the most important, basic-level ones; an LCD system won't be usable before knowing all of these. Level 2 ones are less important, developers may omit them from first releases. Level 3 are unofficial, non-standard connections.
Stud--Stud Inlet
     Level: 1
     Rotation: none
     Slide: none
Stud--Plate Edge
     Level: 3
     Snap: edge between rows of studs
     Rotation: none
     Slide: along the edge
Hollow Stud--Rod
     Level: 3
     Snap: rod through the stud
     Rotation: 360 degrees
     Slide: along the axis
Minifig Head Stud--Minifig Cap
     Level: 2
     Snap: like Stud--Stud Inlet
     Slide: none
     Level: 1
     Slide: none
Shutter Holder--Shutter
     Level: 2
     Snap: both ends of shutter into the bevels of holder
     Rotation: 180 degrees
     Slide: none
Pin--Hole
     Level: 2
     Snap: pin into the hole
     Slide: none
Metal Axle Holder--Metal Axle
     Level: 2
     Snap: both ends of axle into the holder
     Slide: none (physically possible but unnecessary in practice)
Metal Axle--Wheel Town
     Level: 2
     Snap: an end of the axle into the wheel
     Rotation: none (they rotate together)
     Slide: none
Wheel Town--Wheel Town Tyre
     Level: 2
     Snap: tyre around the wheel
     Slide: none
     Level: 2
     Snap: towball into the socket
     Rotation: up to a limited angle in all three dimensions
     Slide: none
Axle--Axlehole
     Level: 2
     Snap: axle through the axlehole
     Rotation: none
This appendix shows drafts of CDL files for some sample parts. The following format is used:
3001 Brick 2 x 4
     Level: 1
     Stud at x = 0, y = 0, z = 1; Direction z = 1; Size x = 2, y = 4
     Stud Inlet at x = 0, y = 0, z = 0; Direction z = 1; Size x = 2, y = 4
The coordinates are expressed in studs and bricks, in an arbitrarily chosen coordinate system and with an estimated precision only. For real CDL files, the currently LEGO CAD software coordinate system is used, relative to a specified point on the part.
3001 Brick 2 x 4
     Level: 1
4733 Brick 1 x 1 with Studs on Sides
     Level: 2
     Hollow Stud at x = 0, y = 0, z = 1; Direction z = 1; Size x = 1, y = 1
     Hollow Stud at x = -0.5, y = 0, z = 0.5; Direction x = -1; Size x = 1, y = 1
     Hollow Stud at x = 0.5, y = 0, z = 0.5; Direction x = 1; Size x = 1, y = 1
     Hollow Stud at x = 0, y = -0.5, z = 0.5; Direction y = -1; Size x = 1, y = 1
     Hollow Stud at x = 0, y = 0.5, z = 0.5; Direction y = 1; Size x = 1, y = 1
     Stud Inlet at x = 0, y = 0, z = 0; Direction z = 1; Size x = 1, y = 1
(Note that all side studs are pointing to the same direction where they are located from the center of the brick.)
4070 Brick 1 x 1 with Headlight
     Level: 2
     Hollow Stud at x = -0.4, y = 0, z = 0.5; Direction x = -1; Size x = 1, y = 1
     Stud Inlet at x = 0.4, y = 0, z = 0.5; Direction x = 1; Size x = 1, y = 1
(Note that the hollow stud is 0.1 units [estimated] closer to the center than in the previous sample.)
6019 Plate 1 x 1 with Clip Horizontal
     Level: 2
     Minifig Hand at x = -1, y = 0, z = 0.5; Direction y = 1
     Plate Edge at x = 0.5, y = 0, z = 0.5; Direction x = 1; Size y = 1
     Plate Edge at x = 0, y = -0.5, z = 0.5; Direction y = -1; Size x = 1
     Plate Edge at x = 0, y = 0.5, z = 0.5; Direction y = 1; Size x = 1
(Note that a Minifig Hand connector does not have a Size property.)
If a LEGO CAD software has been equipped with a full-fledged LCD system, we can take further advantages from that. Some additional thoughts follow in this appendix, to let you see what you didn't see in previous chapters.
CABLES. Electric cables, fiber optic tubes, pneumatic tubes and any kind of flexible equipment can be now easily modeled and handled. The way is the following. We design two special parts for each kind of cable, one for both ends and one for a middle particle. The middle particle is short, its length may vary from some millimeters or less to some centimeters or more, depending on how realistic we want to be. The middle part can connect to another middle part or an end part; the end part can connect to a middle part or a different LEGO part suitable for the tube or cable.
When the user takes a cable, he or she will be prompted for a length and, optionally, for a "density". The density will specify the number of middle parts used to build the cable. The connectors used to build the cable are having a special property: even if the user turned the respective toggle to make connected parts separate when moved, the parts of cables do not separate. The user can move any part of the cable, either an end or a middle part, and the LCD system will move the neighboring parts together with it, as the connections require to do so.
FINAL CONTROL. When a model is ready built, a user can't play with it in current LEGO CAD softwares. With LCD system, they can. We mentioned a list of movable connections found in the model, what the user can view and give commands to connections. In this case, any part connected to a moving part in a non-moving way will move together. But we needn't stop here.
The user can create toolbars, as in several Windows applications, and assign buttons to chosen movable connections, setting what modification should happen by a click. Press a button and the door opens. Press another one and the window closes.
Later, developers may add sliders or disks to toolbars what a user can slide or rotate, and chosen connections slide or rotate along with them. Cables can have a property telling if there is electric current or pneumatic pressure in them; electric or pneumatic parts may have a property telling if there is activity in them, and if yes, the software can know what to do. Finally, a user turns a battery switch on and the car wheels start rotating; and if there is a surface below the car, that can be observed as a connection and the car will start running on.
If these are realized all, the game will almost be perfect; however, it is still hard to imagine that anybody would give up buying real LEGO sets for the purpose of playing LEGO only in simulation. That is the thing what is really perfect, not the virtual one.
COMPUTER PARTS. Electronical parts like the Technic Control Center or the RCX would be harder to emulate, but even this is possible. People are creating softwares to emulate home computers of the 1980s, and they work; programs written originally for these home computers are running well on emulators. An RCX emulator is undoubtedly outside the task of a 3D CAD program development, but it is possible, and there may be living a programmer somewhere who can create a software module for it.
Note: Last Modified: Orion Pobursky 12-Sep-03
Recipient 2007
Kevin Clague
Current Contest Winners
Model of the Month
Scene of the Month
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: Questions About Selling Custom Model Instructions: Confirming LEGO/LDraw Consent
by Timothy Gould - 11 hours ago
by Kevin L. Clague - 11 hours ago
Re: LDDP 2.0 Coming
by Geoffrey Hyde - 17 hours ago
by Willy Tschager - 2 days ago
There are 68 unlogged users and 0 registered users online.
 Log in Problems?
 New User? Sign Up!
