Support our host
News
Software
Reference
Community
Parts Library
About Us
Reference > Tutorials
Published By OrionP on Sunday, September 07, 2003 - 02:06 AM
Printer-friendly page
How Do I Add LDraw Parts To My Library
  • What are LDraw Parts?
  • Where can I find LDraw Parts for my library?
  • How Do I add LDraw Parts to my library? (Method 1: Using MKLIST.exe)
  • How Do I add LDraw Parts to my library? (Method 2: Using MLCad)
LDraw parts are individual files (usually with the .dat extension) that model an individual LEGO piece in a 3D CAD like format. You need LDraw parts, also know as the LDraw library or LDraw library of parts, in order to create any model using any LDraw application. Without the LDraw parts library no model creation would be possible as you would have no virtual LEGO pieces to create your virtual model.LDraw parts come in 3 types of categories: Official, Unofficial, and Non-existent Unofficial. Official parts refers to those parts that The LEGO Company has created physically and that the LDraw community has created virtually and have been certified by LDraw.org. Unofficial parts are similar to official parts BUT HAVE NOT passed the LDraw.org certification yet. Nonexistent Unofficial parts are parts that have NOT been physically created by The LEGO Company but exist ONLY virtually.Note that a one can say a 4th category exist called "Others". The LDraw file format has been used by some in the community to create virtual bricks from other companies other than The LEGO Company, such as MegaBlok, K'nex, etc. These parts are NOT support by LDraw.org as our policy is to ONLY support The LEGO Company brick. See the next section for a list of links to these types of parts.
The images below show examples of nonexistent unofficial parts created by Thomas Burger and what he has created with them. Click on any image to enlarge.
Thomas Burger Race Car Image 1
Thomas Burger Race Car Image 2
Thomas Burger LDraw Parts Image
You can download Thomas's parts from his Brickshelf account
Where Can I Find LDraw Parts For My library?
There are two main locations on the internet where you can find LDraw Parts.
LDraw.org
This is where you can find the official LDraw library. You can download either the complete library or parts updates as they become available.
Lugnet
This is where most developers post unofficial LDraw parts for review. Additionally the LDraw.org Part's Tracker can show you unofficial parts waiting for certification.
If neither of these two sites can offer you the part(s) you are looking for you can do one of two things:
1) Do a google search for the part in question that you are looking for if you know the part number (ex. 3005.dat is a 1x1 brick) or
2) post a message to lugnet.cad requesting if someone is willing to create the part you want for you.
How Do I Add LDraw Parts To My Library? (Method 1: Using MKLIST.EXE)
This example has "extra steps in italics" to show what must be done when you want to install the LDraw parts update or complete library. Furthermore this example assumes that your LDraw installation was done to C:\LDraw.
Pre Step 1 Download the LDraw part(s) that you wish to add to your library. For our example we will use LDraw Parts Update March 12, 2003 file called lcad0301.exe
Pre Step 2 Move the 2003-file to the "C" drive. To do this, double-click on the My Computer icon and select the "C" drive. Next drag & drop the lcad0301.exe file into the "C" drive folder.
Pre Step 3 Click on the Windows Start button and select "Run...". In the run pop-up window type in the following cmd and click the OK button.
Pre Step 4 A small pop-up window similar to figure 1 will appear.
DOS window image
Figure 1: DOS Window (Click on image to enlarge) We need to locate the lcad0301.exe file to be able to run it. To do this we need to get to the C:\> Prompt. If your DOS Prompt is NOT C:\> then type CD..and hit enter to move up a folder. Continue doing this until you are at the C:\> prompt.
Pre Step 5 LDraw.org has developed a simple self-extraction file for each of it's parts update and the complete library. In order to activate the self-extractor you must type the following at the C:\> prompt. lcad0301.exe -y and click on enter. The DOS window will flash a series of text very fast and then stop. Once it has stopped you can close the DOS window.
Step 1 Add the new parts to either the P or PARTS sub-folders under the LDraw folder.(If you followed the Pre-Steps above the self-extraction file will have placed all the new parts in the proper folders, so skip this step.)
Step 2 Double click on the MKLIST.EXE file located under the LDraw folder to update the PARTS.LST file which houses all the current LDraw parts in your computer. Clicking on MKLIST.EXE file cause a small pop-up to appear as in figure 2.
MKLIST DOS window image
Figure 2: MKLIST.EXE DOS Window (Click on image to enlarge)
Step 3 Select D and watch as the MKLIST application begins to re-create the PARTS.LST file based on the filename descriptions of each LDraw part in your library. The window will close once the application is done and you now have an updated PARTS.LST file with the new parts you have added.
How Do I Add LDraw Parts To My Library? (Method 2: MLCad)
If you are attempting to add the complete.exe or parts update files found at ldraw.org please see the Pre-Steps in the section above before following the steps in this section.
Step 1 Add the new parts to either the P or PARTS sub-folders under the LDraw folder. (If you followed the Pre-Steps in the section above the self-extraction file will have placed all the new parts in the proper folders, so skip this step.)
Step 2 Open MLCad (Version 3.00 and higher) and click on the file menu and then the Scan Parts submenu command as shown in figure 3.
MLCad's Scan Parts image
Figure 3: MLCad's Scan Parts command
Step 3 MLCad will ask you if you wish to update your PARTS.LST file as shown in figure 4.
MLCad asking to update PARTS.LST file
Figure 4: MLCad asking if it should update you PARTS.LST fileClick on YES and you are done.
Help Desk Tutorial: How Do I Add LDraw Parts to My Library
Version 1.0
Created by Ahui Herrera, LDraw Help Desk
Recipient 2007
Kevin Clague
Current Contest Winners
Model of the Month
Scene of the Month
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: Looking for part - Hinge Arm 2x2x6
by Michael Heidemann - 21 minutes ago
Re: "LGEO" and "L3P v1.4 BETA 20080930"
by Jeff Boen - 19 hours ago
by Dave Heintz - 19 hours ago
Introduction to LPub 4 video
by Jim DeVona - 20 hours ago
There are 75 unlogged users and 0 registered users online.
 Log in Problems?
 New User? Sign Up!
